DAVID'S WEB SITE
Date:  11-9-2015
Manual Reference:  8.2.l
Brief Description:  weight on wheels switch
1 ENSURE AIRCRAFT IS AT ENPTY WEIGHT AND SUPPORTED ON JACKS
2 REF TO FIG 8.2.L.1 WEIGHT ON WHEELS SWITCH
3REMOVE BOTTOM JAM NUT AND THE KEYED WASHER FROM THE SWITCH
4 THREAD THE SWITCH INTO THE MOUNTING FLANGE ON THE TRUNION UNTIL THE AWITCH CONTACTOR IS JUST TOUCHING THE TRAILING LINK. SNUG THE TOP JAM NUT DOWN AGAINST THE FLANGE.
5 REINSTALL THE KEYED WASUER ABD THE BOTTOM JAM NUT. TIGHTEN BOTH JAM NUTS SO THAT THE SWITCH IS HELD AT THE DESIRED POSITION.
6 CONNECT THE SWITCH TO THE ELECTRICAL HARNESS.
7 INSTALL SAFETY WIRE
