DAVID'S WEB SITE
Evolution
7.2.G
INSTALLING THE AILERON CONTROL SYSTEM
CUT PUSH PULL ROD TO LENGTH.
TABLE 7.2.G.1 OVER ALL LENGTH.
TABLE 7.2.G.2 PUSH PULL ROD IN BOARD.
TABLE 7.2.G.3 PUSH PULL ROD OUT BOARD.
TABLE 7.2.G.4 PUSH PULLROD CENTRE.
INSTALL THE CONTROL STICK.
PLACE CONTROL STICK INTO AILERON TORQUE TUBE.
SECURE WITH BOLT ( AN4-16A) WASHER (AN960-416L) AND LOCK NUT ( AN365-428A)
TIGHTEN SO THAT THERE IS NO SLOP IN THE STICK.
INSTALL THE TORQUE TUBES USING BOLT (AN4-14A) WASHER (AN960-416L) AND NUTS (AN365-428A)
AILERON HARD POINT.
WERE THE TORQUE TUBE CONTACTS THE SKIN AT THE CONTROL STICK LOCATION CREATE A HARD POINT 1 1/2" TO 2". FIG 7.2.G.7
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
