THE SENSING RANGE OF THE REED SWITCH IS SUCHTHAT IT WILL STOP THE FLAPS AT A DIFFERENT POINT DEPENDING ON WETHER THE FLAP IS TRAVELLING FROM UP TO DOWN OR FROM DOWN TO UP. DETERMINE THE MOST ACCURATE 50% POSITION OF THE FLAPS WHEN THE FLAPS ARE MOVING FROM THE UP POSITION,AS THIS IS THE NORMAL PRODCEDURE AND MOST CRITICAL.
WITH A SMART LEVEL HELD ON THE BOTTOM SIDE OF THE FLAP AND THE FLAP IN THE UP POSITION . ZERO THE LEVAL ELECTRICALLY ACTUATE THE FLAPS FROM UP TO 50%
ADJUST THE POSITION OF THE 50% SWITCH UNTIL 23.5 TO 24 DEG IS OPTAINED
VERIFY BOTH LEFT AND RIGHT FLAP WITH THE SMART LEVEL
