DAVID'S WEB SITE
Evolution
10.2 G
HYD PUMP MOUNT
THE HYD PUNP MOUNT IS NOT MOUNTED TO THE CENTRE PARTION DUE TO THE AUX FUEL TANK INSTALLATION.
1 MANUFACTURE A MOUNT AND LOCATE IN THE AFT BAGGAGE COMPARTMENT4 3/4 INCHES AFT OFF THE AFT SHEAR BOX, 2 " LEFT OFF THE AIRCRAFT CENTRLINE.
2 BOND THE MOUNT TO THE FUSALAGE USING HYSOL, AND ROUND FLANGES.
3 USING THE HYD PUMP AS A GUIDE, MARK AND DRILL THE HOLES FOR THE HYD PUMP. ENSURE THE PUMP IS NOT TOUCHING THE BOTTOM OF THE FUSALAGE.
REFER TO CHAPTER 11 HYD SYSTEMS, SECTION 11.2.C HYD RESERVOIR AND PUMP UNIT
4 CHECK THE CLEARNCE OF THE HYD PUMP TO THE ELETATOR TORQUE TUBE.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
