1 MAKE N 8"X 4"X 2" BLOCK OUT OF MEDIUM DENSITY FIBERBOARD ( MDF) OR NON-POROUS WOOD. COVER THE BLOCK WITH CLEAR TAPE SO THE CARBON LAYUP CAN BE REMOVED AFTER CURING.
2 MAKE A 6 BID CARBON LAYUP AT 45 OUT OF 12" X 8" SHEETS
3 WET UP THE 6 BID ON THE TABLE THEM LAY IT OVER THE BLOCK.
4 AFTER CURING, REMOVE THE PART AND CUT THE PART TOMAKE TWO SHELFS AS SHOWN
5 LEVEL THE AIRCRAFT.
6 ENSURE THE SHELFS ARE LAVEL FORE ANF AFT, AND SIDE TO SIDE.. BOND TO THE FUSALAGE USING HYSOL, HOLD THEM IN PLACE WITH CLECO FASTENERS UNTIL THE HYSOL CURES.
7 INSTALL THE ELT AND OPTINIONAL MAG 3100 USING THE MANUFACTURERS INSTRUCTIONS.
