2 ENSURE THE SHELF IS LEVEL FORE AND AFT AND SIDE TO SIDE, THEN BOND IT TO THE FUSALAGE USING HYSOL. HOLD THE SHELF IN PLACE USING CLECO FASTENERS UNTIL THE HYSOL HAS FULLY CURED.
3 INSTALL THE MAGETOMETER ACCORDING TO CHAPTER 20 AUTOPILOT, AND THE LASTEST REVISION OF THE GARMIN GRS 77-GMU-44 INSTALLATION MANUAL P/N 190-00303-10
NOTED
ONLY BRASS OR HIGH QUALITY STAINLESS STEEL SCREWS AND WASHERS MAY BE USED FOR INSTALLING THE MAGNETOMATER. ANY MAGNETIC HARDWARE IS UNACCEPTABLE.
