DAVID'S WEB SITE
Date:  11-10-2015
Manual Reference:  9.2.D
Brief Description:  ASSEMBLY OF THE MAIN GEAR DRAG LINK
1 ASSEMBLE THE DRAG LINKAS SHOW IN FIG 9.2.D..2 COMPLET DRAG LINK ASSEMBLY
2 PRE ADJUST THE LENGTH TO APPROXIMATELY 3 1/2: CENTRE TOCENTRE OF THE ROD END BEARINGS
3 CENTRE THE HINGE BRAKET (150-0006) ON THE HARD POINTS AS SHOW, AMKING SURE THE HINGE BRAKET IS PLACED SO THAT THEDRAG LINK IS:
PERPENDICULAR TO THE TRUNNION AND THE DOOR
PARELLEL TO THE EDGE OF THE DOOR
4 INSTANT GLUE THE HINGE BRAKET IN POSTION.
5 MATCH DRILL THE HOLES.
6 COUNTERSINK THE SCREWS AS DESCRIBED IN 2.3.A. DRILLING AND BOLT HOLE TOLERANCES.
7 REINSTALL THE HINGE, WET SET THE SCREWS, MAKING SURE TOADD FLOX
8 FINISH THE EXTERNAL SURFACE WITH 2 BID GLASS LAYUP AS SHOWN 9.2.D.3. HARDPOINT FINISHING
9 ATTACH THE DRAG LINK TOTHE MAIN GEAR TRUNNION
