DAVID'S WEB SITE
Evolution
3.2.L.7
INSTALL ELEVATOR UP TRAVEL STOP
BONS A 1 -2-3/4 PHENOLIC BLOCK USING FLOX.
REF TO FIG 3.2.L.7 FOR LOCATION.
CONNECT THE AFT ELEVATOR PUSH PULL TUBE TO THE ELEVATORCONTROL HORN.
DETERMINE AND MARK THE LOCATION OF THE ELEVATOR STOP.
BOND A 1 -2-3/4 THICK PIECE OF PHENOLIC TO THE STERN POST USING FLOX.
ALLOW FLOX TO CURE THEN GRIND THE PHENOLIC UNTIL AN UP ANGLE FOR THE EVEVATORSOF 22.5 +/- 0.5 DEG.
GRIND THE PHENOLIC MORE THAN THE AMOUNT TO ALLOW FOR THE THICKNESS OF THE CARBON LAYUP.
USING FLOX CREAT A SMOOTH TRANSITION BETWEEN PHENOLIC AND THE STERN POST. COVER WITH 4 BID CARBON LAYUP
FIG 3.2.L.7
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
