WHEN THE GEAR IS UP, THE TRAILING LINK WILL MAKE CONTACT WITH THE INSID OF THE UPPER WING SKIN. TO COMPENSATE FOR THIS, A HARD POINT NEED TO BE INSTALLED.
CUT A 3 " DIAMETER CIRCLE FORM PHENOLIC BLOCK..
LOCAT WHERE THE HRD POINT IS REQUIRED.
dECORE THE WING SKIN IN THAT AREA. AND CREAT A HARD POINT.
APPLY A 4 BID CRBON LAYUP, STAGGERING EACH LAYUP BY 3/4"
