DAVID'S WEB SITE
Evolution
5.2.L
INSTALL STATIC WICK MOUNINT BRACKETS
LOCATE STATIC WICK MOUNTING BRAKET TO UNDERSIDE OF WING.
THEY MUST BE MOUNTED SO THEY ARE PARALLEL TO THE DIRECTION OF FLIGHT.
LOCATE FLIGHT REFERENCE LINES ON WING.
MEASURE FROM THE REFERENCE LINES PARALLEL , GIVING REFERENCE, LINE FOE THE STATIC WICK BRAKETS.
PREP AREA WITH 80 GRIT SAND PAPER. CLEAN WITH ACETONE.
BOND STATIC WICK BRACKET IN POSTION WITH HYSOL.
COAT AREA WITH CONDUCTIVE PAINT.
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
