DAVID'S WEB SITE
Evolution
5.2.O
WING FUEL VENT
INSTALL WING FUEL VENT INTO THE WING TIP THROUGH THE ACCESS PANEL.
CONNECT THE CHECK VALVE TO THE FUEL TANK (545) WITH FLOW LINE TOWARDS THE TANK.
CONNECT T FITTING (AN824-6D) TO THE CHECK VALVE.
TUBING 5052-.375/.035 AS REQUIRED. FOR CORRECT ALIGNMENT.
NUT COUPLING (AN818-6D AND SLEEVE (AN819-6D) AS REQUIRED FOR CORRECT ALIGNMENT
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
