DAVID'S WEB SITE
Evolution
4.2.I.1
U JOINT AND FWD CAPSTN
U JOINT LINKS THE CAPSTAN TO THE RUDDER PEDAL ASSEMBLY.
ASSEMBLE CAPSTAN 4.2.C.
BOLT CAPSTAN BETWEEN UPPER AND LOWERR BELL CRANKS.
INSERT ASSEMBLY BETWEEN UPPER AND LOWER RETINING PLATES.
U-JOINT IS ATTACHED TO THE TORQUE TUBE USING, TAPER PINS.
FIG 4.2.L.1
Evolution Home
1207
10 fuselage
11 hyd sys
12 fuel sys
13 brake sys
14 seat/saet belts
15 main door
16 heat/vent/air con
17 baggage door
18 pitot static
19 elec and avionics
20 auto pilot
21 nose gear
3 horizontal stab /
31 ice rain protecti
4 rudder
5 wings
6 flaps
7 aileron
8 landing gear
9 gear doors
duplicate inspection
