Brief Description: Assemble flap nose rib/brackets and drill to spar
Assembled Rib(s), Bracket(s) and spacer x 6. Used two 1/16th inch washers and a 1/4 inch bolt/nut to keep bracket aligned while drilling holes to spar (enlarged to final size with #30 reamer). Both spars done.
