Murlins Web Site
Date:  10-27-2014
Number of Hours:  4.00
Manual Reference:  7-12
Brief Description:  Begin assembly of left aileron
Rivet reinforcing plates and nut plate to spar.
riveted A 905 ribs before doing the nose ribs. Drilled out flush rives (2 ea.) riveted nose ribs, THEN re rivets A 905 ribs.
Discovered that I had not dimpled skins or ribs so I had to dimple ribs 'in-place' and do the skins using the squeezer.
Clecoed bottom skin to ribs, top skin to ribs, then nose skin to bottom / CB tube/ and around to top skin/spar.
