Brief Description: Clamp and drill trim tab hinge to elevator
Cut small bocks of wood to wedge loose hinge to elevator spar - worked well and kept things well lined up. Used spare piece of hinge material to line up / measure gaps; drilled one hole on each end to set line, then drilled holes in between. Drilling went well with no problems.
