Brief Description: Sand and epoxy trim tab foam wedges / ribs
Did a final fit on foam ribs and had to sand them down a bit. Mixed epoxy and installed ribs. Clecoed and clamped. Epoxy is setting up. Just read / realized that I should have match drilled the hinge. Now I need to figure out how to clamp / mark / drill hinge. Hope I don't need to order a whole new trim tab ....
Getting ready for epoxy fun!
Ready to mix epoxy and apply
Realized here that I should have already drilled out the hinge.
