Murlins Web Site
Date: 1-20-2013
Number of Hours: 4.00
Manual Reference: 6-6
Brief Description: Clean, dimple, prime Stiffeners and Dimple Skin
Cleaned all stiffeners, dimpled, and primed ready to install. Dimpled skin stiffener holes. Very carefully used dimpler and table to not create any new skin bend/wrinkles. So far so good. Marked, solder gun cut protective covering, and removed plastic covering where riveting will occur. Used dimpler table to support skin and bring things higher to work on. Much better results.
Used stiffener and spar as guide to melt outlines. Worked well
Inside skins are ready to clean and prime - much less primer area but only removing plastic where stiffeners, ribs and spar attach. Outside skin rivet areas protective cover removed and re covered with blue masking tape. Ready to rivet and minimal skin exposed. Should be a lot few scratches.
AND shop was warm today, almost 70!! First time in over a month!
Stiffeners primed
Protective skin removed and replaced wit tape
Ready for scuffing, cleaning, and priming.
