Murlins Web Site
RV9A
Drill pushrod tubes / rod ends
Insert. rod end into pushrod tube and used drill press to drill six equidistant holes. clecoed in place.
First drill with drill press seems to pull rod end into tube slightly.
All holes drilled.
One bit broke.
small tubes drilled straight through
Set up for drilling first hole
Last hole in large tube, clecos
All four tubes done.
RV9A Home
1122
Ailerons
Delivery
470
Flaps
Inventory
Practice Projects
415
