Murlins Web Site
Date: 2-1-2013
Number of Hours: 4.50
Manual Reference: 6-8
Brief Description: Left elevator disassemble deburr dimple
Begin the disassembly, deburr, and dimpling process. Start with CB assembly. Cleaned, deburred, dimpled, and primed. Disassembled spar, ribs, reinforcement plates. Cleaned, deburred, and dimpled. Countersunk top of E 907 elevator trim spar. (clamped to overhanging plywood strip, drilled holes and used clecos to hold while countersinking. Dimpling the elevator skin - had to unscrew the dimple table top from work bench. Skin is dimpled - #30 bottom, #40 top.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
