Mark Sanders RV-10
Date:  12-31-2019
Number of Hours:  2.75
Manual Reference:  28-7-1 thru 4
Brief Description:  Drill and dimple floorpans and other components
Mistake made with this section. When dimpling floor pans, I dimpled incorrectly and for some unknown reason, had the dimples point up in the floor pan. Of course the dimples should be pointing down (plans did not call this out and is an opportunity for improvement) so that they will eventually mate with dimples that will be added to the top of the floor ribs. Had to order new L & R floor plans to match drill and dimple. All other components match drilled per plans. Also need to dimple for nutplates. Was hard to determine which side they go on but finally figured it out looking forward in the plans. Another opportunity for the plans to clarify these types of call outs with simple notes to help us first time builders. Time included all edge finishing of floor pans.
