Wrapped up tunnel access cover support plate riviting and starterd left/right nose gear tension fitting. For nose gear tension fitting, specificed rivits are too short so used -6 instead of -5. Same for F100E-L/R center angle to nose gear tension fittings used 4-7 instead of 4-6 to attach to L/R Forward rib Asy.
