Mark Sanders RV-10
RV-10
Rivet upr/lwr channels to firewall mounts, firewal
Did not rivet longerons to gusset. Waiting until after I rivet foremost hole toward firewall in upper/lwr channel flanges (6 holes remaining).
Also riveted gussets to side channels per plans and lower tab in the F-1002 fwd fuse bulkheads to the upper flange of the 1041 side channels.
Used squeezer for most of the upper/lower channels but did use hand squeezer for lower channel, lower flange.
RV-10 Home
1046
478
566
