Brief Description: Dimple per plans skins,1015A outboard seat ribs an
Big gotcha in the plan here with the 1015A rib and intercostal. Had to create dimple die holders and use with rivet gun to dimple intercoastal and rib. Worked out well to accept flush rivet. Used squezer around rib top edges and close quarters dimple die along the bottom and bottom sides.
Very time consumimng and did both left and right ribs/intercoastals.
