Mark Sanders RV-10
Date:  12-21-2019
Number of Hours:  8.25
Manual Reference:  27-4-7
Brief Description:  Rivet Tunnel Access Cover Panels & Nose Gear Fitti
Wrapped up tunnel access cover support plate riviting and starterd left/right nose gear tension fitting. For nose gear tension fitting, specificed rivits are too short so used -6 instead of -5. Same for F100E-L/R center angle to nose gear tension fittings used 4-7 instead of 4-6 to attach to L/R Forward rib Asy.
