Put together the HS main (rear) spar fitting, channel, and angle pieces to make the HS main spar. It all went together well, but I mis-set a bunch of rivets and had to drill them out and redo them. Clearly I need to work on getting the rivet gun perfectly square to the rivet. : In the end it all came out quite well!
