DONALD'S WEB SITE
Sonex
HS Clip, Spar Fitting Cleanup
Made HS spar clip from 0.063" Aluminum sheet. Getting the radiused bend correct was tricky, but it worked out okay. I also cleaned up the forward spar fitting and drilled the pilot holes.
Sonex Home
642
394
