DONALD'S WEB SITE
Date: 7-19-2010
Number of Hours: 2.25
Brief Description: Elevator skins cut to size
I cut the elevator skins to size tonight. When I did the rudder I did it with snips. This time I decided to use the bandsaw to make it easier and more exact. When I was doing the rudder I had a 6 TPI wood blade on the bandsaw (which Sonex says is fine)...I tried a bit of cutting on the rudder with it and the cuts were very rough and the saw had a lot of chatter.
Now I have an 18 TPI metal cutting blade on the saw, and it cuts like a laser. Fast, straight, little effort required and almost no material lost/destroyed. Because I only have a 9" bandsaw, I had to lop off part of the end of the skin before the portion where the real angles cut would fit under the blade (pic 1). I also got some interference from my drill press, which is mounted nearby. I worked around it, but I might think about moving the press farther down the workbench...
Once the skin was cut on the bandsaw as close to the lines as I dared, I moved the skins to the work tables, clamped them down, and went to work on them with a fine file, 150 grit sandpaper, and scothcbrite pads. In the end both skins turned out great, some of my best work so far!
bandsaw elevator clearance
elevator skin clamped to bench for filing/finishing
completed left & right elevator skins
