Dan "Mitch" Jimenez
RV-8A
Left Wing
4-30-2006
Left Wing Rear Spar
Assembling the rear spar. Pictures say it all. Next things I need to do are prime, countersink and rivet the plates to the rear spar.
W707G Matched drilled to W 707A-L Rear Spar
W707E Rear Spar Reinfore plate To W707A-L
W707F, W707E, W707G, matched drilled to Rear Spar.
RV-8A Home
362
Garage/Shop Setup
Garage/Wing Set Up
Leading edges
Left Aileron
Left Flap
Left Fuel Tank
Left Tank Test
Left Wing
Right Aileron
Right Flap
Right Fuel Tank
Right Wing
Right wing tank test
Wing Craddle
Wing Paint Priming
Wing striping
Wing tips
