Dan "Mitch" Jimenez
Date:  4-24-2006
Number of Hours:  5.00
Manual Reference:  7-2
Brief Description:  Left Wing Main Spar
Started the left wing construction. and I need to tell everyone that you need to read the plans carefully. While we were constructing the tail section the plans were very explicet. i.e. use drill bit 30, dimple with #6 etc. The wing plans are different. The plans from now on expect you to already know what drill bit to use, what countersink to use etc. Once I understood that, then the wing plans became easier to use. I ended up buying the wing videos so that makes the construction even easier.
Our Aunt Rita Shelley helping me drill the main wingspar.
Aunt Rita took over and did the countersink drilling.
Countersink holes on left wing main spar.
