Dan "Mitch" Jimenez
RV-8A
Lowering the wing Jig,
If you try this method, make sure you use a stud finder and find the ceiling main beams. This whole Jig must weight over 200 lbs with all the 4x4's.
The pivot points.
Here I am lowering it into position.
A little lower.
RV-8A Home
362
Garage/Shop Setup
Garage/Wing Set Up
Leading edges
Left Aileron
Left Flap
Left Fuel Tank
Left Tank Test
Left Wing
Right Aileron
Right Flap
Right Fuel Tank
Right Wing
Right wing tank test
Wing Craddle
Wing Paint Priming
Wing striping
Wing tips
