Debug ground wire problem with fuel sender. Ground is not working as described in directions. Am moving fiber washer on ground screw to above ground wire, so that terminal is in contact with face of sender....works good that way. ZAC tells me it should work as described, that I should clean screw and contact point to solve the problem. No, no change. Am going with moving washer.
