MIKE'S WEB SITE
Date:  5-29-2021
Number of Hours:  4.00
Manual Reference:  33-08
Brief Description:  Attached Brake lines, secured fuel lines
Attached all the Aircraft Specialty brake lines. I inverted the fuselage on the rotisserie and it made it much easier to install. Again, I had to use multiple documents to get it right. AS makes a good product but the installation instructions could be better if combined into one document. I routed the cables through the holes I enlarged yesterday then attached snap bushings in all locations where they pass through a rib or bulkhead. You have to split the snap bushings and attach them after you run the lines through the holes.
Upside down fuselage, easier to install hoses
Hoses routed per Beringer plans
Upside down view w/fuselage flipped
