Attached all the Aircraft Specialty brake lines. I inverted the fuselage on the rotisserie and it made it much easier to install. Again, I had to use multiple documents to get it right. AS makes a good product but the installation instructions could be better if combined into one document. I routed the cables through the holes I enlarged yesterday then attached snap bushings in all locations where they pass through a rib or bulkhead. You have to split the snap bushings and attach them after you run the lines through the holes.
