Installing the Scat tube could be a challenge as the tube is very tide, but a little bit Vaseline helped a lot! Unfortunately I had not enough from the 2" tube but too much from the 1 3/4", hope to make a trade with our local Plane service shop. Also installed the exhaust heating element, which needed extra holes and bigger scat connections, luckily there was enough material supplied to make the right assembly.
