Replaced the barb connectors for the pito tube and static pressure with Festo push in connectors as they dont reduce the tybe size as barbe do. Also pressure tested the pito and static pressure with a suringe check for any leaks and functionality. Worked perfect. Also connected the carby heat and cabine heat push rods and tested.
