The seat belt install is not straight forward as per manual as I have the wider landing gear which has different type of struts. Mounting the Seat belt as per manual would conflict with the ruder cables and put a lot of pressure to the bottom and the seat structure, beside the belt would be twisted and worn unevenly, possible premature failing! With the two Stainless Steel angles which I cut out of a piece SS Angle, I get the exact distance and angle for the seat belt to go over the seat without pressuring against the seat fibreglass supports!
