Currently we have over 40degC outside; inside the shed is close to 45deg, therefore all the work will be only in the aircon area of the shed!
W Patterson has given me the idea in his build log to have a glare shield made for the instrument panel; sometimes spare time gives you ideas! Definitely a useful thing. I'll take a similar approach except of bending an alu shield I use a premade fibre glass sheet 1mm, glue it to alu supports and sandwich it in foam and carbon fibre. This will be strong and light. Started cutting 14 slots for the alu supports and removed all gelcote in this area.
