Brief Description: Flap Bracket and Landing light install
To get the remaining flap bracket into the right spot I was thinking of a simpler method then the one described in the manual. I used a peace scrap 100mm alu channel and cut one side off to get an L shape, which I screwed with two metal screws onto the fuse. Then I marked the hole for the hinge bold drilled it and checked position with the flap, all ok. Now when the wing is removed I can simply bolt the bracket to my alu support and drill the mounting hole into the fuse. Next I positioned the landing light and glued it in place first only butt glued it, next time I'll fibreglass all around.
