Michaels Web Site
Date:  11-8-2020
Brief Description:  Elevator Stick position
As previously mentioned by Mark Patterson the control stick will knock out the glass panel as it goes too far forward. To prevent this from happening I used some old Conveyor belt rubber 10mm drilled a 4mm hole to have the rubber fixed and also use a cable tie to keep it in the right position!
Works also as a damperner.
