Cut the first bracket and mounting trails showed the wrong position of the indicator with linkage under pressure. Second bracket had the right distance from the fuse which got glued to the fuse. Marking the drill position on flap arm and wiring the flap indicator to a data cable and covering all in heat shrink.
