After some more little filling job around the airplane at the back, HS, rudder and canopy frame, I had to leave the fuse to rest. Therefore I started some less messy work and installed the break cylinders to the pedals. To make it as described in the manual it required some small mods and a few more washers. The cylinder push rod attachment had to be filed round around a corner, to turn easy. As I had some more time, I cleaned the front wheel block and made the leg attachment to fit easily into the block.
