To get the lock into the right angle, I used the level on the centre of the firewall lining up with the rudder and place the lock handle exactly in the middle. So far it looked ok. From the side I moved the handle a little bit back to line up better with the fuse shape. Embedded all mounting nuts on the canopy frame in epoxy flox
