Filled the leading edge from the elevator and cut access hole for the crank shaft bolts on the underside of the elevator. Also I enforced the glue joints at the crank mounting area and squared them up. Spend again time with sanding; try to finish off as close as possible so that not much paint preparation is left at the end.
