Final wing Assembly before final painting, the plan is, after the wings are painted they get assembled next time on the airfield. As the aileron push rod access hole was just cut to minimum size into the fuse for testing and to get just clearance. After testing the push rod, length was cut to fitt and for full movement, it was found that a few more mill of clearance were required.
