I had to trim the window a little bit, and sanded it where it was glued with 80 grid sand paper. Because the windows are already in shape of the fuse it was very easy to glue them in place. I had not need for the alu bracket's as described in the manual, two foam blocks and a bit of tape did the trick. Afterwards I filled all in with epoxy glue.
