Because the fuse flange is not as even I decided tho flox the washers and also the supports into the fuse so that when installed a flat surface will support the structure. The alu back plates were cleaned and sanded with 60 grid, the supports waxed and all good packed with epoxy and flox. After the epoxy cured there were a nice flat surface for the supports and a solid back plate for the engine mount.
