Today I manufactured the support for the pedals, cut it to length to fit left and right side and cut all the 4 angle pieces. Drilled all holes as per manual, the lightning holes were a bit confusing as the picture hade more then you could have with the required spacing. Therefore I only have 5 holes and not 8 as on the picture in the manual! All what is left is to drill the 1.25" hole, for which I ordered a big step-drill. The corners on the firewall had to be rounded to get the support as close as possible to the top as I didn't want to cut in the fibreglass.
