Assembled the front wheel, used some talcum powder for inside the tier and on the tube and lined it up with the balance mark (red dot on tire). All went without problems only the turn stop bolt need to be the longest supplied (AN4-31A is too short) as this version has not the phenolic block and is maybe wider?
