Brief Description: A lot of Sanding and little Jobs
After sanding the bottom fuse joint, my wife and I managed to turn the fuse upright and I did the same with the top joints, sanded of the gelcoat and glassed one stripe over the joint. A step between the two half’s will require some filling of one side to even out. Also sanded the dashboards vent holes and filled in the canopy strut mount with glue, to make it solid connected with the dashboard.
