Started the engine wiring, with all the temp sensors and the fixed cable length it was a chalenge to get all in place. It started in a mess but cleared up soon. At the end all was need secured and connected. Had to order more wire from Aircraft Spruce and also a master solenoid as otherwise the vertical Power unit cant be disconnected!
